Carro Armato M 11/39 (Modelik)
- Jorzik
Welcome to the next building relationships with Italian tank Carro Armato M11 / 39.
Model was designed by Modelik item no, 4/2002 in scale 1/25. At the beginning I mached skeleton of the fuselage. They are laser-cut parts.
Unfortunately, these parts have errors. After removing these errors I combined the elements of the skeleton. Then I began banding hull. Unfortunately, the rear upper fuselage parts are not accurate and need to be cut to proper size.
- Jorzik
Re: Carro Armato M 11/39 (Modelik)
Himaps писал(а):Good luck!
Do you like small tanks?
Not only small, this tank is bigger than L6/40.
- Jorzik
The hull was made.
Stuck on larger covers. Unfortunately that model is inaccurate. Some parts of the shell are too big or too small. For as much as it gave corrected.
- Jorzik
Hey.
The next step in the construction are the wheels and suspension components main road wheels.
- Jorzik
Hello.
Slowly are created various items of equipment. I made idlers and the exhaust system. At the rear flaps I have done new hinges.
On the sides of the fuselage I made reinforcing elements.
- Jorzik
Welcome to the next scene.
This time I present the side parts of the wheel suspension. I made also the rear wheels with the elements of attachment to the hull.
The small support wheels also made.
Currently working on the tower, barrel already done.
- Jorzik
Hello.
A lot of details came to the model. I made wheels and joined the guards. The tower got machine guns. I also started riveted hull. I use conical rivet 1 mm, made of resin by Model-Kom.
- Jorzik
We start the delicate seasoning pasta.
Conical rivets went in motion (painting is a challenge!). I did little extras, not included in the model, hopefully make model more attractive. Jack, spare wheels, buckets, canisters any more tents ... The chassis consists of four sets already done. Model pre-soiled, On the whole model will have a layer of desert dust.
