Fiat Ansaldo L6/40 (SuperModel)
- Jorzik
Hello!
It's time to introduce the next relationship with the construction of the model. It will be a model of Italian tank Ansaldo Fiat L6/40 publishing by Super Model in 1/25 scale.
The model is very simple, it will be corrected by me, many items are made from scratch, much will be converted.
At the beginning, model's cover and tank photo.
The skeleton of the hull was glued on 1mm cardboard, and after cutting glued together.
Plating elements ready to affix to the skeleton.
Re: Fiat Ansaldo L6/40 (SuperModel)
The unusual prototype and scale model. And what a publishing house? Not seen before. Can I ask for a review of the magazine?
- Jorzik
Hi
This model was released by the publishing house already non-existent OMIX from Katowice.
This Publishing House has published more than a dozen paper models of airplanes and vehicles.
Presented by me model L6/40 was developed by Marian and Jarosław SOBEL, at 1/25 scale.
These designers have developed later, among other things, the model of TYPE 97 SHINHOTO Chi-Ha for "MODEL HOBBY".
Scans do not reflect exact color, scale of that model.
Model nicely drawn, however, are differences in, the elements of the tower are darker than others.
Also spare parts has been placed on the back cover of the glossy paper and color those parts to significantly different from the others.
The model is simple and very simplified compared to the actual object.
Some elements are simplified and many have not joined in the project. However, the model is very accurate.
Therefore, with the help of available materials I will this model greatly improved in the process of construction.
- Jorzik
Hi
Update.
The hull was made, all nicely fit. Internal sides of fenders added in the appropriate color.
Update.
- Jorzik
OK new update.
At this stage of the work done front and back hatch, I started doing parts of ventilation engine.
I made the reinforcing elements the bottom of the hull.
- Jorzik
Hello
New update
After the finite elements of the engine cooling system started a chassis and wheels.
Rocker arms were slightly improved, they reached the cover between the control arms, on the side panels glued strips. Wheel covers were of a different color, they were extracted from spare parts to a uniform color.
I made a small supportive wheels. Main wheels got outer rings.
New update
- Jorzik
Welcome to the next installment.
I made a tower on the hull come the following items. Everything fits well. The status of the work on the present moment.
I glued the tensioning wheel and small supportive wheels.
- Jorzik
Hello.
Work on the model getting close to the end.
The suspension elements with wheels will be glued to the proper place.
Currently I am working on the tracks. They are laser cut.
Also I made a few additional items like canisters, pickaxe, boxes, buckets.
- Jorzik
Done.
Italian tank moves to the salons. Model is simple, to make it closer to the actual object I made many components, not included in the cutout, the other I had to improve. The biggest problem was the choice of color retouching that is not I expected. But it is and enjoy.
